convert mp4 7650 file to nim,realone 9210
3 replies · 4,329 views · Started 24 November 2002
:robot:
how to convert the file mp4 from nokia 7650 videocamm to nim, realone or any nokia 9210 format???????plese........
What is the wxtension of MP4 files on 7650?
I guess the MultimediaConverter(Pro) can dig you out.
If you manage to put them on PC--U will be able to convert them to nim.
Other ponit ov views?
Real producer is a git for only converting from very specific file formats. Your best bet is to use an older Indeo format to convert. So first you'll need to convert the MP4 file into Indeo.
[quote="SwitchBlade"]Real producer is a git for only converting from very specific file formats. Your best bet is to use an older Indeo format to convert. So first you'll need to convert the MP4 file into Indeo.[/quote]
Good advice, VirtualDub should do this for you, you can find a link to download VirtualDub (free) on my website (www.n9210.co.uk)
