I had a nokia 3230 but swapped it for a nokia 6670 i backupd each contact i had on my old phone and tries to transfer them on my 6670 using pc suite. now when i try to put them back on it keeps saying operation failed. i was wondering if you could tell me where the contacts folder is on the system so i can transfer them on my new phone as i need them badly!!
P.S. i have tried using the cable and bluetooth.
menhel wrote:I had a nokia 3230 but swapped it for a nokia 6670 i backupd each contact i had on my old phone and tries to transfer them on my 6670 using pc suite. now when i try to put them back on it keeps saying operation failed. i was wondering if you could tell me where the contacts folder is on the system so i can transfer them on my new phone as i need them badly!!P.S. i have tried using the cable and bluetooth.
you could try using this program called contacts transfer... but make sure u backup ur device memory into your mmc or you mite lose ur contacts... you can get the program from
http://personal.inet.fi/private/riihimaki/s60/pbktrans.html
