Hi I am new to all about symbian, my problem is that I have buy slightly used nokia 7610 but old user had change the security code of 7610 which I dont know and I cant even find him again from which I purchased my set. now when i use *#7370# it ask master code of it which I dont know. I have also used DKU3/4 master code but my set cant accept them please help me I am in trouble my IMEI is 358390000026362
Master Security Code of N7610
There's no way around this accept to get the phone reflashed / serviced.
ranamubasshir wrote:Hi I am new to all about symbian, my problem is that I have buy slightly used nokia 7610 but old user had change the security code of 7610 which I dont know and I cant even find him again from which I purchased my set. now when i use *#7370# it ask master code of it which I dont know. I have also used DKU3/4 master code but my set cant accept them please help me I am in trouble my IMEI is 358390000026362
enter this code "0022064622".then it will work
Dear vinodsm,
I have tried this master code thousands times but it cant work please help me I am in trouble I dont want to flash my new set its software is manufactured on 2-6-05, I will wait for you bye
check ur serial number, if its the one u've given us, then the master code shoul work
0022064622
try this : 0022064622
your master code for nokia 7610 is
mc :0022064622
Hello, i have nokia 6680 and i need master code, imei 358358007785934, thank you please if can send my in my email [email][email protected][/email]
vinodsm123 wrote:enter this code "0022064622".then it will work
Dear Friend Plz.. reply me what is the procedure to change my old user code plz.. mail me [email][email protected][/email]
krupesdoshi wrote:Originally Posted by ranamubasshir
Hi I am new to all about symbian, my problem is that I have buy slightly used nokia 7610 but old user had change the security code of 7610 which I dont know and I cant even find him again from which I purchased my set. now when i use *#7370# it ask master code of it which I dont know. I have also used DKU3/4 master code but my set cant accept them please help me I am in trouble my IMEI is 358390000026362Dear Friend Plz.. reply me what is the procedure to change my old user code plz.. mail me [email][email protected][/email]
Try calculating your phone's master code at http://www.nokialockcode.com
Hi, im in dire need of unlocking my phone, its the initial code you put in to get the phone up and running after you power it on. Iv had nothing but problems with this and have had to go back to my old phone, AT&T says they could unlock it BUT it might fry my phone, its only 3 weeks old, I dont wanna waist the 200 i paid for it, can anyone help get it unlocked Thanks Jeff:con?
[QUOTE=ranamubasshir;256189]Hi I am new to all about symbian, my problem is that I have buy slightly used nokia 7610 but old user had change the security code of 7610 which I dont know and I cant even find him again from which I purchased my set. now when i use *#7370# it ask master code of it which I dont know. I have also used DKU3/4 master code but my set cant accept them please help me I am in trouble my IMEI is 355034004855477[please tell me to put a general code for my phone
My imei: 359732003937286 I find on the web my master lock code :2735314160. But when I get this digit number in lock code then has notice: code error.
I tried format by pressing: power +call(blue)+*+3 and formating is finished. But i press 1234 or 273531460 not work, lock code error.
Please help me. thank you!
my phone is nokia 7610 and i dont remember security code pls help 😞
an i used dct3/4 mcode calculator for pc software but not work this master code pls help...
my imei: 357087007530989
thanks
