panasonic x700 resetting
3 replies · 2,317 views · Started 21 April 2006
hi, my phone is rebooting after almost every conversation.
also, i deleted some files i thought junk, and now i can't open some old sms and can't enter options for mms.
i tried to format it using the 2 *# codes and the green+*+3 procedure, but i won't work.
can anyone help, pls?
can't believe i haven't tried that 😊 that was so easy...
well, it worked (the formatting), can now access options for mms, can't say anything about the resetting though 😃
thanks a lot.
although.. i have one question... is formatting supposed to start before rebooting, right before restarting i mean? coz after i entered the code the phone wouldnt switch off completely, the keyboard light was on and i left it alone for 10-15 mins and then i got bored and took the battery off 😊 so... maybe it was formatting when i took the battery off coz now i dont have all the origianl software installed (like quickoffice and ringtones).
something is definitely ok, coz i can install software now (installer wouldnt work before).
