Is that any way to transfer mp3's from other phone to my N-Gage cls with bluetooth directly to MMC?? Coz many mp3's which have 3,5MB and more can't be copied - too little free place. I've Kingston 512Mb and standard 32Mb memory card
SW ver. 3.30
mp3's directly to MMC
try using msdriveE bro,it allows u to receive msges directly to the mmc. if u have any problems try to upgrade your firmware to 4.03 or higher
manual says it can only read up to 256 mb cards, so anything higher would be a problem. if yours, mem card 256 higher worked, please tell me the manufacturer. thanks!
My MMC+ 512Mb Kingston works properly on my N-Gage except transferring by USB cable - PC won't find the phone (I have card reader so it's not a problem)
how can I transfer files from other phone to my Nokia N-Gage with bluetooth directly to MMC?:con?
Use 'msdrivee'
dude I have N-Gage QD......so I can't use that
i'm using pqi 512mb and it works fine. the pc reads the mmc using the cable.
try using a different cable maybe it will work.
after i install msdrivee on my n-gage classic so i run the program cause when i do it it comes up with some error
jaymarfal wrote:manual says it can only read up to 256 mb cards, so anything higher would be a problem. if yours, mem card 256 higher worked, please tell me the manufacturer. thanks!
I have 4Gb Mobymemory and works great!
marcel333 wrote:Is that any way to transfer mp3's from other phone to my N-Gage cls with bluetooth directly to MMC?? Coz many mp3's which have 3,5MB and more can't be copied - too little free place. I've Kingston 512Mb and standard 32Mb memory cardthis is reduculas
SW ver. 3.30
u need to use msvdrivee then just direct save into mmc, and also u need the software which are handy file, file manager,select q etc. its just like explore
