is anoyone know how to install themes for n91? :frown:
Themes for N91
They're SIS file like previous version of S60. However they need to be in th new (well sort of new) sis file format. I know Symbian Themes is actively working on getting S60 3rd Edition support as soon as possible. I think you can find some extra themes from the Nokia support site.
Correct!
I have installed the 3250 themes on a N91 and they work.
I found that themes in Nokia Support Site.
Also here: http://symbian.mobilethemes.com/themes/nokia_n91/page1.jsp
seem to have Themes... if they are already in new OS, I don´t know, and also I don´t have tested in the N91!
Try...!
i've try the nokia3250 theme. but not all of them works fine.. and i also tried the themes from symbian, and it also doesnt work . do u know where can i find the 3rd generation themes? thnx..
i mean 3rd edition themes for my N91.:tongue:
You are right, speedshooter, not all of them works...
I had the luck of install 2 of them, and they work.
Strange... Is the same OS and the same display!
Try SymbianThemes - site!
Good luck.
i've already tried symbian themes . and it doesnt work's too. anyone knows where can i get theme 3rd edition? :banghead:
Symbian Themes will support 3rd Edition soon(ish), aside from that I'm not aware of anywhere that has specific 3rd edition themes.
Symbianthemes now support the 3rd edition.. it has around 5000 themes for the 3rd Edition
Siddharth wrote:Symbianthemes now support the 3rd edition.. it has around 5000 themes for the 3rd Edition
Unfortunately those are not working for N91. :frown:
I tried it... When u installing the theme is fine but when U apply as a theme, it turn back to default theme.
Those themes are working fine with N3250. 😉
