Doubt 6630 : Want to Change from 64MB to 1GB
3 replies · 2,453 views · Started 23 April 2006
I have a 64MB RS MMC, that came with the phone .. and since then i havent changed it. I wanted to buy a 1GB OR a 512MB RS-MMC. But i have a few questions:
Note: I own a 6630.
1) How do i go about buying it, is there any Criteria for an RS-MMC ?
2) What does the 6630 support : Dual Voltage or Single Voltage.
3) Does 1GB slow down the phone usage or take up battery power.
Would appreciate your help and advices.
Regards.
dudez...i oso usin nokia 6630 and i oso upgraded my memory card to 512 mmc and WALA !!! nutin happen juz kind da slow....not very slow ...abit slow onli .....but oso nutin ......and oso can upgrade to 1GB if u wan
Hello dh,
I've just got 2 pieces of 1Gb DV RS-MMCs for my 6630.
Manufacturer: CnMemory
Price: very fair - less than 40EUR per piece.
Result: +++++
NO speed problems, seems to be much faster than original one.
Capacity: 1 Gb
Transfer speed: 100x
Reading max. speed 14,7 MB/s.
Writing max. speed 8,6 Mb/s.
Not enough?
When using USB 2.0 card reader (e.g. making backup to PC) best result could be achieved.
Life time: 1.000.000 hrs (114 years !!!)
Data keeping time: 10 years
W x H x T: 24mm x 32mm x 1,4mm *
*SD transform adapter included (aprox. double size)
Weight: 1,5 g
Vibration resistance: 15 G
Schock resistance: 1.000 G !!!
You just have to take care about choosing right one - it should be dual voltage type 1.1 and 3.8 V !!!
Since I do not need both one of RS-MMC is available. If you are interested in contact me.
Tom
