PC Suite for 7650 version 1.o or 1.1?
3 replies · 2,121 views · Started 24 November 2002
I have tried using PC Suite 7650 v1.1 and see that is makes hundreds of backup files called xxxxxxx.dat. With PC Suite 1.0 it backs up the files so you can see what they are in their relative directories. Uniinstalled 1.1 and went back to 1.0 as that way I can know what files are where and what names - especially Contacts.cdb file!
Anyone else find this with their setup?
(Mine - XPPro with TDK BT)
confirmed!
I have installed 1.10 now, and i am afraid to go back to 1.0 because i had much trouble getting my noname BT dongle to work with mrouter.
I am using.. well tryint to use version 1.0.0.76 of the PC suite for Nokia 7650 under Win XP - Sr1, and never works, I cannot believe Nokia does'nt support Windows XP for this software, what were they thinking? ANyways where do you get the 1.1 version and will it solve any problems?
maybe i'm to stupid for htis, but where did you get 1.1 from...? just went to nokia.com, downloaded the 27mb file, uninstalled my pcsuite, installed the 'new' version and help/about still says 1.0...?
could anyone post the entire url to the file...?
THanks!
