*.sis installation on 3250
17 replies · 11,213 views · Started 23 April 2006
I cannot install *.sis programs on my new N3250...
Does somebody knows WHY??
TNX to everybody 😊
Giovanni from Padova, Italy.:con?:
I had install in a N91, the 3250 Themes!
Maybe, is a security problem.
Seach in Tools, Aplications Manager, Options, Definitions, Install Software - change to Yes.
I think is that the problem, because in N91, everythink work�s OK!
Is the same OS and the same screen resolution.
You have to make sure the software / files you are trying to install are S60 3rd Edition compatiable.
Damn! The navicore GPS software is only for S6.0v2!!
On the box it works also on N70.
Thank you for the answers...
I know Navicore are planning a S60 3rd Edition version - might be worth contacting them to find out if you will be able to get it.
:icon1: Thank you for emailing Nokia Careline.
In response to your inquiry, please be advised that the Nokia N70 supports
the Symbian 8.1 operating system and Series 60 rel. 2.8 user interface.
However, the Nokia 3250 supports the Symbian 9.1 operating system and
Series 60 rel 3.0 user interface.
Pertaining to the Bluetooth modem connectivity issue, it would be best to
contact the Nokia Careline Italy Technical Support Professional from a
landline with the mobile and computer ready. This will also enable them to
guide you through the steps and provide you a solution. :icon1:
I'll write here next answers... Stay connected:icon14:
I've tested the NOKIA STILL IMAGE EDITOR on the phone, and the installation doesn't works...:icon13:
Hmm tht strange. Might just want to leave the phone for 10 minutes and see it the install resumes?
i hope symbian hasnt put the axe on its own foot by changing the software compatibilty. it wil take a long long time for consumers to get used to the new 3rd edition softwares, and longer to make them
I've installed the editor:icon14: , but only in offline mode. And the installer is TOOOOOOOOOOOOOOOOOOOOO SLOOOOOOOOOOOOOOOOOOW.:icon13:
In the installer infos there is the "test" specification.....
It's a nice program.
mr.pinky wrote:I cannot install *.sis programs on my new N3250...
TNX to everybody 😊
Nokia 3250 is a useless and a piece of trash when it comes to installing symbian softwares
nj7 wrote:I had install in a N91, the 3250 Themes!
Can you explain this again cause in my nokia 3250 there is somthing like this
Tools, Aplications Manager,Settings,software installation, then in tht , there is 2selection (#On and singned only) so which should i choose...?:con?
Manduck wrote:Can you explain this again cause in my nokia 3250 there is somthing like this
On! If you choose the signed only, most of software woul be refused!
