Worms Forts!
23 replies · 8,497 views · Started 23 April 2006
I have tried running worms forts on my N70, but to no avail.
The N70 was in the compatibility list, but im not the only one who has had problems.
Has anyone else?
Is it fixable?
Serj wrote:I have tried running worms forts on my N70, but to no avail.
Has anyone else?
Is it fixable?
Is the software freeware? If not you may want to remove the attachment as sharing copyright software is against the forum rules and may earn you a ban. Apologies if it is legitimate free/shareware.
S.
Gah!
I didnt even stop to think about that!
Has anyone else had any problems with it though?
Serj wrote:Gah!
It could be that that specific version of the game is not compatible with the N70 :frown: I have tested lots of trialware both as .sis and .jar that's meant to be compatible with Series60v2 and they weren't useable on the N70. Bummer when it happens but it does happen. One good example is Nokia's own Sensor software, works on the 6680 and other handsets, doesn't work with the N70.
S.
how odd, im using V2 aswell.
When i try to open the game, it opens for about 1/2 a sec then closes. Wierd.
im talkign about the java version. i think you might be talking about the c++ version which i have no idea about
Serj wrote:umm, im just running the firmsware version out of the box.
Hehe what I'm getting at is are you both on the same network? For interest my handset exhibits the same behaviour as yours, ie it didn't work. I'm on Orange.
S.
I have it for my N70 on Orange and I can't get it to work either and I have V2.0537.1.7 firmware, 😞
Carl,
Im getting my firmware upgraded to v5 tonite, hich will debrand it also.
I suspect that alot of the software that doesnt work that SHOULD work, will do after the upgrade.
Ill let ya know.
CJackel492 wrote:I have it for my N70 on Orange and I can't get it to work either and I have V2.0537.1.7 firmware, 😞
Carl,
you need to find a better copy.would upload mine but dont wanna get banned
Cj, turns out i was trying WormsForts 3D before.
this is a 2d version.
I still havnt got working 3d version.
