hi to all i have the nokia n80 and i transfer sis files from my pc to the mobile through the usb cable but the mobile tells that the format is unsupported.do i use wrong format? ehay is the problem?can someone help?
need help installing sis files
jacky_cy wrote:hi to all i have the nokia n80 and i transfer sis files from my pc to the mobile through the usb cable but the mobile tells that the format is unsupported.do i use wrong format? ehay is the problem?can someone help?The N80 runs S60 V3 and as such all previous software (.sis files) are incompatible. You'll have to wait for the new software to roll out. AFAIK, there are only two pieces of software out at the moment that have been recompiled for the range of S60 phones, one is for taking screenshots the other is a file manager.
S.
