n80 general help
5 replies · 6,357 views · Started 25 April 2006
hi to all. i recently bought the nokia n80 and i have some questions that i want to ask.
1) how can i remove the shufle tunes when i use the camera? can i delete them from the mobile?
2) i want a detailed description to setup the wlan on my mobile. (i have a wirelles router linksys)
3)i tried to install applications with sis format but the mobile tell that format not supported.whaqt is the format for n80 application
if someone help me with these question i will be very thankful
1) Not sure what you mean?
2) You should be able to create an Access Point using a specific hotspot in Connection Manager (more details in your manual) or you can use the EasyWLAN option when you try and connect. EasyWLAN means the phone will then scan for hotspots.
3) Applications must be S60 3rd Edition compatible.
