:frown: I can�t install new themes.
During the installation appears this message:
Unable to install!
compatible with skins series 60 support
version 0.00
WHERE CAN I DOWNLOADIT?
Can anyone help me.
Thanks.
Unable to install!
version 0.00
Can anyone help me.
Thanks.
You can't. It is an indication that you are trying to install a theme that has been created for newer phones than the one which you have (a phone based on a newer Series 60/S60 version).
but i just installed the newest pc suite and i cant install themes at all.. example: im trying to install a theme that worked on my phone before via the old pc suite. now it wont be installed at all..how can it be possible??
just erase all or the newest theme installed on phone..some themes are made wrong and after you installed it you cant install other themes.. it worked for me! "davids crystal theme" made all other themes uninstallable.. Ive just erased it and now all the other themes work fine to install 😊
tojo909 wrote:just erase all or the newest theme installed on phone..some themes are made wrong and after you installed it you cant install other themes.. it worked for me! "davids crystal theme" made all other themes uninstallable.. Ive just erased it and now all the other themes work fine to install 😊
Same idea!
