I've been reading threads about how people synchronise their phones with Outlook, is this outlook express, or microsoft outlook? and how's it done, does a new account need to be added or something like that or is it just through the Nokia PC Suite.
NK
Microsoft Outlook needs Outlook Express. This can be found with IE installation file. It sounds stupid that outlook would need something else to get started..but yes..and its really :x :x
so how's it done? (synced from nokia 7650 to microsoft outlook)
You will first have to get the Outlook Express component for Outlook to work. It is then straighforward. Get the phone connected to PC Suit.
On the PC Suit, in the Sync tab, check on Calender / Contacts and hit the sync now button.
But this procedure is too obvious. Was there something more to your Question?
yeah, my pc suite doesn't work which is why i wouldn't know about it 😊 but thanks for your help.
Oops!!
So, Getting the PC Suit to work should be ur immediate problem, since this is the only way to sync, as of now.
Hope someone comes up with a workaround soon
