Installing problems!
5 replies · 2,678 views · Started 27 April 2006
ok just got a old a925 and tried to install some softwares that are ment for nokia v60 phones and this message shows up "Install Series product ID v60" or something like that.
where can I get this? and I have seen that I need a p800 or p900 version as well.....
really need help here😞
this is what I am trying to install
FEexplorer.sis
Vnes.sis
You can't install Series 60 (S60) apps on an A925.
Install UIQ 2 apps (apps for Sony Ericsson P800 should work, at least).
ok but does anyone here know any emulators for a925?
looking for softawers for it as well.....
Thanks😃 tried Egboy too and works great😊
but I have another prob😞 The computer doesn't detect my mobile when I'm using the Pst program and checked the avialable ports but only COM 1 is available....
the mobile is connected in COM 7....
I need drivers(I think) but where can I get that?
trying to flash it with GeneriX A925 REL 35.80.61
what type of connection you using to connect the phone and i knew only the USB and if you use so, try to get updating the usb device
and i would like to ask any one where i can find free application download for motorola SLVR
and thank you
