Hi, really quick, easy question. Does the N80 have a 2.5mm or 3.5mm audio socket? Does it come with an inline remote like the N91?
Finally are there many differences between the N91 and N80's audio playback capabilities? Do you get album art for instance?
Cheers, Nick
It doesn't have neither, it has Pop-Port for headsets, but if you buy the Nokia Audio Adapter AD-46 or Nokia Audio Adapter AD-15, that both convert the pop port connection into 3.5mm jacks.
The N80 came with PopPort for stereo headsets... but it came with the standard popport to 3.5 mm audio plug converter in the box ... you don�t need to buy it as additional accesory ...
And about the audio capabilities in comparation with N91... same .. except that N91 came with 4 gig of minidrive ... and N80 can hold MiniSD of 2 gig as max.
Cya!
Cheers for the info guys.
When does miniSD cars come in 4 gb?
