how do i delete applications that i dont want after i install them using the pc suit. thanks
deleting installed application
just go to Tools/App. manager. then find the application you want to remove from the list. press 'c' key or select 'remove' from option menu. that's all !
i tried that. i installed an ap called photo jive and when i click the 'c' key it says unable to delete (in options menu there is no revome)
use a file exploere fexploerer or seleq. go to either e:\stem\apps c:\system\apps & see if jive is still there. btw the folder could be anything(it doesnt nescessarily haver to be the name of the app)
Try to boot in 'safe mode' . ( turn your phone off and then turn it on while pressing 'pen' key ) . Then try to remove application in a normal way.
steff2632 wrote:use a file exploere fexploerer or seleq. go to either e:\stem\apps c:\system\apps & see if jive is still there. btw the folder could be anything(it doesnt nescessarily haver to be the name of the app)
sorry what is a file explorer. do i need to download it onto my computer? then hook up my phone via usb? sorry im new to this
here have my version its freeware so dont worry.would give you a direct link but the site is down
domi is in hospital:frown:
thaks for the program. it has done the job
