heeeeelllllpppp!!! 3650 frozen
6 replies · 2,798 views · Started 29 April 2006
please help my 3650 which i have now had for many years will not start, when i press the on button it simply appears with the NOKIA on the screen and stops their. I have tried taking the battery out and starting it again, i hav tried removing the memory and sim card bt no success. i love this phone to bits and any suggestions would be appreciated.
also i was wondering if i were 2 just change over the memory and sim card over to another 3650 would all the information go on to it or would i lose some and if so what??
please help me 😊 thanl you!!!!!!!
http://www.allaboutsymbian.com/support/item/Cant_boot_up_the_smartphones_stuck_in_an_endless_reboot_cycle.php
ok I checked this out but it seem not to work!
expension card by the way? never heard of that before:redface:
this is how I did this
I pressed and hold the green phone button then * then 3 and hold it until the mobile stopped and turned off and nothing happened...
what now?? Did I missunderstood the text or something?(yea a swedish guy here)
Really need help here so please care to reply would be very greatfull!
hmm ok people ask for help here and wait days to get an answer on an active site.....NO ONE helps here THANKS😡 why don't you all break it to me and says that my phone can't be repared or something!
:icon4: I NEED HELP!! THE MOBILE MUST BE FIXED!!!!!!:icon4:
same troubles
can't fix this shitty mobile!!!!!!!!!!!!!!!
nokia logo, then disappear and nokia logia and again!
from time to time I see App Error message into a dialog box by several times and it get locked after 2-3 times.
The 3+*+green key reformatting does not work on old phones like the 3650.
If it doesn't start up at all, try removing the memory card. If that's not enough, try with another battery. If that's not enough either (or you don't have another battery), then take it to a Nokia repair/service center: http://www.nokia.com/repair
just returned from Nokia Repair Service and they said:
IRREVERSIBLE LOGICAL FAILURE
what should I suppose to do with this?
I strongly believe that our local service don't know a sh!t about this mobile, but if they are okay?
Should I drop it to the trash??
