Hard Resetting
3 replies · 2,687 views · Started 30 April 2006
Hi ,
I am thinking of Hard Resetting my 9500 as I seem to be having a few issues. Nothing major. But I have been using it for 2 years nows and I feel that lot of junks seems to have accumulated as I have installed and uninstalled lot of applications.
I believe that hardresetting would take it back to factory status. Just one question. MY original firmware was 4.22. Then I upgraded to 5.22 for making it Blackberry compatible. If I hard reset would it go back to 4.22 or will it stay at 5.22.
Nilesh
Thanks for the reply.
Please could you also advise if there are any other issues to be aware off after a hard reset. Obviously I would need to reload all the the 3rd party applications including Blackberry.
My only concern is that after the hard reset will there be any problems on reloading all the applications and the phone working well.
Regards
Nilesh
topiwala wrote:Thanks for the reply.
Regards
Nilesh
This
http://3lib.ukonline.co.uk/9500afresh.htm
may help!
Steve Litchfield
