Hi, I just got a mobile from Ebay, a Nokia N70, but trying to change somethings the code lock is asked and the default 12345 entered does not work, i dont know how to make a new code (the seller does not remember if he changes it), the IMEI is 357093002799793
is it posible to do something, thank you very much
Lock Code Urgent Plzzz
get it flashed. take it to a nsc & they will flash it so that everything is deleted.
but if the phone si locked(network specific) then theres nothing you can do except get on to the network & pay the price they ask for
I tried some webpages which generates the master code depending on the imei of the phone... but it does not take it...
what can i do ?? the phone is locked to te 3 (UK) network
thanks
new nokias (from 6630) are bb5 so all free code gens wont work. & btw by using them youve probs used up your 3 chances to enter the code.youll now have to get it directly unlocked which is rpetty much impossibe again due to it being bb5.if you havent used up all 3 then phone 3 & ask for an unlock code or just use their payg service
