i was so excited to use my new msi bluetooth device. i saw all on the threads that there is some problem, then i just follow it... i can sync with my pc suite and transer files vice versa. there's no problem at all. im using WinXP pro and downloaded the latest driver on msi website
but i didnt sure about what's the latest from this three so i donwloaded them all.
MSI Bluetooth Software 1.2.2.15 (bt41)
http://download.msi.com.tw/support/swr_exe/bt41.exe
MSI Bluetooth Software 1.2.2.15 (bt45) this one i installed
http://download.msi.com.tw/support/dvr_exe/bt45.exe
MSI Bluetooth Software 1.2.2.4 (bluetooth)
http://download.msi.com.tw/support/swr_exe/bluetooth.exe
what's the latest driver from the 3 i mentioned???
i'm just wondering two things. why do they make a a bluetooth places and place a Bluetooth Serial Port when they dont actually connect each other, when you try to connect, remote device disconnected something like that.
the second thing is, is there a way to transfer files from pc to phone that you would not need to go to bluetooth places and try to drag and drop the files from the public folder, and why does the right click procedure when you try to upload files and chose
send to --> bluetooth --> other
and a window pop-ups and try to search a device, even though my phone bluetooth enabled, the computer doesnt seems to detect it
did i do something wrong or missed something about this???
can you help me??? thank you in advance
