APP. Keylock turns off screen with TOMTOM
4 replies · 2,325 views · Started 01 May 2006
When i use jjkeylock or Autolock, the both turn off my screen will driving. The screen stays on, when i remove any keylock software.... is there a way to fix this.
Had the same problem, but in TomTom go to the options and then screen settings and there you choose to have the screenlight always on. When it is always on the keylocker won't work anymore in TomTom.
I had this option already.
What i found - was, when the screen timeout ( in the phone setup ) was set to 5 sec. It turn off the screen in TomTom. But if i set it to 15 sec., it will stay on :con?
