Rafe takes a look at Nokia's main smartphone music device - the Nokia N91, and assesses its capabilities as a music player, as a smartphone and in real world usage.
Interesting review and it seems like a worthy purchase. Between the N91, E61, N80 and even the 9300i, its geting really confusing as to what to purchase.
Though i really dont get this comment:
A 4GB hard disk is also starting to look a bit small, especially when you consider the 4GB of flash memory in the forthcoming W950.
They are the same capacity! I can understand the flash would require leg battery power and make it less bulkier, but those werent the points you put across.
What I meant byt that is having flash memory is better. A hard disk is acceptable when it gives a large amount of memory. Sorry it wasn't clearer!
you wrote: The N91 has a 20x digital zoom (resulting in very smooth zooms)..
my n91 has 6x digital zoom only.. is it a typo error?
tsupatsupa - I'll have to check my notes on that as I don't have the N91 any more. It might be a differences between software. It's all digital zoom so the benefits are doubtful.
I agree, benefits of having 20x as digital zoom is really doubtful.
The review of N91 is awesome for novice users covering basic features........
But Man N91 is all about Music so you should describe detailed sound quality output of the phone i.e Hows "BASE" using default headsets,Sound quality,loudness comparing with W900 etc.....
Hope you will consider these
THX
Hi , I got the Nokia N91 about 2 weeks ago and i have to say im loveing it.
To answer about the Sound it is quality plus useing the settings correctly can give you fantastic sound quality depending on what you are listening to.
One thing i might point out that doesnt seem to be released by people.
It only has one Speaker , so the phone on its own ,ie playing with its own speaker wouldnd be great , but again the quality is fine for just that , i think you are really better pluging it in to a Speaker set if you want the full quality.
Anyway, if you are looking for answers to your questions thne drop by here and they will be answered.
http://n91mac.wordpress.com/
macbuckley
