free themes for 3250 are available finally for 3250 at symbianthemes.com check it out !!!!!!
Free Themes 3250 available now!
Yey!!!
thanxxxxxxxxxxxxxxxxxxxx man
I have visited the site checked out all the themes but unable to download any of the themes
you gotto register and select your phone model in ur profile to make themes work for u
Tried this also - I have downloaded the .sis files to my Phone but when I tried to i nstall them to the phone it's not getting installed.
Tell me whwther you have been succeded in installing any new theme to your n3250 from that site...
I have installed 20 new themes from that site on my 3250 u need to register and in ur profile settings u need to select 3250 as ur phone model
one more site zedge.no
Thanks a lot buddy, Zedge worked....
symbianthemes.com will work perfectly....they have around 500 free themes for 3250...just register yourself properly ....only then you can install themes
Yes, now its Ok
Last time when I registered - I forgot to give my Device No. [i.e. Nokia 3250].
Now I have edited my profile and its working fine
Thanks a lot BUDDY
Now, did you found out any antivirus also for this phone???
sourav wrote:Yes, now its Ok
Now I have edited my profile and its working fineThanks a lot BUDDY
jhhhhhhhhhhhhhhhhhhhhhhhhhhhh
What kind of joke is this?
It's good
thanka lot man
thanx
hahahaahahhahahahaha
thaaaaaaaaaaaaaaanks
:con? well, i have visited the site (symbianthemes.com)...i was able to download the theme successfully but when i tried to install it on my phone...it was not possible..there was an error message "Security Warning: Application is untrusted and may be harmful to your phone"....what should i do?
Wirelessly posted (Amin's buddy: Mozilla/4.0 (compatible; MSIE 6.0; Symbian OS; Nokia 6600/5.53.0; 1657) Opera 8.60 [en])
u sud click ok 2 get it instald on ur cell.
mai i know the site name ?
Thanks Man 😊
Thanks Man 😊
thanxxxxxxxxxxxxxxx man
i cant recieve service msgs on my 3250 (for checkin balance etc) wen i send the service msg it shows 'done' and nothin else happens. plz help me to solve the problem
Wirelessly posted (Nokia3250/2.0 (3.18) SymbianOS/9.1 Series60/3.0 Profile/MIDP-2.0 Configuration/CLDC-1.1)
bugmenot wrote:free themes for 3250 are available finally for 3250 at symbianthemes.com check it out !!!!!!
themes for nokia 3250
bugmenot wrote:Yey!!!
download theme
thanx
is there any free theme sites other than zedge and symbianthemes.com
Another website for free theme download >>
Does anybody see that when you go to music player, it's not the same picture as the theme you selected.
But some themes on http://gallery.mobile9.com, they change.
