Hello:
I'm testing my app and I'm finding several test errors that I can not
pass. I'm compiling to Nokia S60 2nd FP3 (Nokia N70)
So afterall I've tried Symbian Signed Tool with the simple HelloWorld
generated by Carbide vs 2.0.1. I've found this:
PKG-04: Uninstall provides complete removal of all files and the
installed data.
This test always fails. Maybe the test application doesn't consider the
install log??
PHN-01: Service Interruption. (call, SMS, MMS, alarm, charger)
This test doesn't allow me to do the charger test, when it says to
press next and plug the charger it jumps to the next test witouth
letting me connect the charger.
This is a part of the log, I think the alarm fails:
- <dll name="C:\DigiaAppTest\Plugins\AppScreenMonitor.dll"
time="44.890625" action="load">
<log time="44.890625" type="dll" name="AppScreenMonitor">Searching
for image 'C:\system\apps\apptestlite\tests\alarm.png'.</log>
<log time="60.046875" type="dll" name="AppScreenMonitor">Timeout
expired. Execution terminated.</log>
<status time="60.046875" type="dll" name="AppScreenMonitor"
setteststatus="Yes">Fail</status>
<globalvariable time="60.046875" variable="AppScreenMonitor::Result"
value="Fail">Variable set</globalvariable>
<time time="60.062500">60.062500</time>
</dll>
And related to the call visualization test:
time="1.421875" action="load">
<log time="1.421875" type="dll" name="AppScreenMonitor">Searching for
image 'C:\system\apps\apptestlite\tests\call.png'.</log>
<log time="61.562500" type="dll" name="AppScreenMonitor">Timeout
<status time="61.562500" type="dll" name="AppScreenMonitor"
<globalvariable time="61.562500" variable="AppScreenMonitor::Result"
<time time="61.578125">61.578125</time>
</dll>
I just press next and call with other mobile to the testing mobile, I
saw the notification and then I hang up.
MEM-01: Low Memory Startup. Also fails.
- <dll name="C:\DigiaAppTest\Plugins\AtStartupTester.dll"
time="1.921875" action="load">
<log time="2.250000" type="dll" name="AtStartupTester">[heap 24576
bytes] Panic: Font Utilities 0 in phase Construction</log>
<log time="2.312500" type="dll" name="AtStartupTester">[heap 25600
<log time="2.375000" type="dll" name="AtStartupTester">[heap 26624
<log time="2.437500" type="dll" name="AtStartupTester">[heap 27648
<log time="2.500000" type="dll" name="AtStartupTester">[heap 28672
<log time="2.546875" type="dll" name="AtStartupTester">[heap 29696
<log time="2.609375" type="dll" name="AtStartupTester">[heap 30720
<log time="2.671875" type="dll" name="AtStartupTester">[heap 31744
<log time="2.828125" type="dll" name="AtStartupTester">[heap 32768
bytes] leaked 12 heap cell(s), 1 handle(s) and 0 request(s)</log>
<log time="2.984375" type="dll" name="AtStartupTester">[heap 33792
<log time="3.156250" type="dll" name="AtStartupTester">[heap 34816
<log time="3.296875" type="dll" name="AtStartupTester">[heap 35840
<log time="3.468750" type="dll" name="AtStartupTester">[heap 36864
bytes] leaked 20 heap cell(s), 3 handle(s) and 0 request(s)</log>
<log time="3.640625" type="dll" name="AtStartupTester">[heap 37888
<log time="3.828125" type="dll" name="AtStartupTester">[heap 38912
<log time="3.984375" type="dll" name="AtStartupTester">[heap 39936
<log time="4.171875" type="dll" name="AtStartupTester">[heap 40960
<log time="4.343750" type="dll" name="AtStartupTester">[heap 41984
<log time="4.515625" type="dll" name="AtStartupTester">[heap 43008
<log time="4.687500" type="dll" name="AtStartupTester">[heap 44032
<log time="4.859375" type="dll" name="AtStartupTester">[heap 45056
<log time="5.046875" type="dll" name="AtStartupTester">[heap 46080
<log time="5.218750" type="dll" name="AtStartupTester">[heap 47104
<log time="5.390625" type="dll" name="AtStartupTester">[heap 48128
<log time="5.562500" type="dll" name="AtStartupTester">[heap 49152
<log time="5.734375" type="dll" name="AtStartupTester">[heap 50176
<log time="5.921875" type="dll" name="AtStartupTester">[heap 51200
<log time="6.093750" type="dll" name="AtStartupTester">[heap 52224
<log time="35.578125" type="dll" name="AtStartupTester">[heap 81920
bytes] Kill: Kill -33 in phase DestroyEnvironment</log>
<error time="210.484375" type="dll"
name="C:\DigiaAppTest\Plugins\AtStartupTester.dll">Finished startup
testing. 87 iterations performed.</error>
<status time="210.484375" type="dll" name="AtStartupTester"
<globalvariable time="210.484375" variable="AtStartupTester::Result"
<time time="210.500000">210.500000</time>
</dll>
Where is the problem here with Hello World?
And finally I've noticed that running the test, the current theme disappear.
If helloworld doesn't pass the tests...
Is there any application that passes clean the testing process?
Regards, David.
=, (\_/) ,= David Jorge
jgs / Bat (___)Factor\ Deimos Space
Ronda de Poniente 19
Edificio Fiteni VI
28760 Tres Cantos
Madrid, Spain
Tel +34 91 806 34 50
Fax +34 91 806 34 51
