Low Memory Tool Min Hep Size on 8.1a
1 replies · 0 views · Started 04 May 2006
Low Memory tool user guide explains about the Minimum free heap that
whem Low Memory is first run, the UI platform is detected and the
correct value for that platform version is configured"
Does anybody know how much memory is necessary for a Nokia 70 (Nokia 2nd
Ed. FP 3, Symbian 8.1a) ?
Because it doesn't detect anything.
=, (\_/) ,= David Jorge
jgs / Bat (___)Factor\ Deimos Space
Ronda de Poniente 19
Edificio Fiteni VI
28760 Tres Cantos
Madrid, Spain
Tel +34 91 806 34 50
Fax +34 91 806 34 51
Hi David
You're right, the default is not set in the tool for S60 FP3. I'll look into
this.
In the meantime, you can calibrate this yourself. The lowmem tool includes a
minimal application "simpleapp" - simply run lowmem on this APP. The first
memory value that this succeeds on to completion is the minimum value you
can use. This will probably be somewhere around 40960
Regards
Hamish
"David Jorge" <[email protected]> wrote in message
news:KsNh2m4bGHA.1040@extapps30...
> Edificio Fiteni VI
> 28760 Tres Cantos
> Madrid, Spain
