Did someone tried the "Opera Mini" on your Sendo X? I get an error msg, while installing it.. Got any idea?
Opera Mini
I've been using it for ages, it works fine.
dheep wrote:Did someone tried the "Opera Mini" on your Sendo X? I get an error msg, while installing it.. Got any idea?
That's because you're not using the proper installer (i suppose that you took the Nokia 3650 or similar installer).
Either navigate to Opera's wap site site from your Sendo and download from there (it'll automatically give you the proper version) or go there http://www.opera.com/products/mobile/operamini/phones/ and in the "Other" category choose Sendo X
Hard luck! Am doing everything right.. During the end of the install, it shows "Removing..." and finally "Install failed". Something wrong in my Russian device.. :frown: I even did a hard reset.. Nothin' seeks to work out..
dheep wrote:Hard luck! Am doing everything right.. During the end of the install, it shows "Removing..." and finally "Install failed". Something wrong in my Russian device.. :frown: I even did a hard reset.. Nothin' seeks to work out..
Can't help you there. I did have this exact same problem when i tried to install on my Sendo X Opera Mini 2 for Nokia 3650 that i had downloaded from Opera's web site. But then i went to opera's wap site using the phone's wap browser, downloaded it from there and everything went fine.
Maybe the fact that your phone is in russian has something to do with it but it sounds surprising. Of course, you could try to reformat your phone and try again but that's a bit extreme. If nothing works you could drop an email to Opera's support team to let them know about the problem.
Thanks elp.. It worked.. I reformated the phone and then, downloaded it via wap and installed it..
Everything seems perfect..
