Infected by comwarrior
7 replies · 10,575 views · Started 05 May 2006
hi
folks... my 3230 nokia phone is infected by comwarrior virus.
il tel u what all happend. i recieved a mms from one of my contacts and there was a .sis file and a txt file as attachment.
i installed the sis file thinking it may be an animation or anything sent.. OOPS!!!:con? it was a virus.my phone stared restrating every other minute. and strated sending mms randomly to numbers in my addressbook.
then i formatted the phone using the code *#7370#. but the restsrting problem continued and in addition a text " infected by comwarrior" appeared in the place of logo??
what do i do now?? i have lost all my data in my phone? y isnt the virus removed even though i have formatted the phone? is the OS affected?? do i need to get the OS reloaded??
I would be very grateful if any one can please answer all questions??
i am too worried!!!!:icon13:
I have no experience in this, but have you tried removing the MMC card? Chances are you installed it there, and the reformat would not have affected it?
Have a look on the f-secure site for some removal instructions (or any other anti virus company).
hey
thanks a lot the anti comwarrior.sis helped me in removing the virus.
but i had to install fexplorer to remove the logo!!
thanks again
joewiljoe wrote:hey
thanks again
try to format again the phone, maybe can solve the problem😊
thank you, thank you, thank you.
honestly, this is the only tool that worked 4 me
but just 4 u guys out there, i had toi scan using an antivirus when i was done, and it found an infected file and deleted it.
thanx again
Urs
a happy guy😊
I have the same problem, but my phone not restarting, just sending sms randomly to all contacts...... It is comwarrior virus? :con?
