Audio Quality on E60?
9 replies · 3,498 views · Started 06 May 2006
1. Can anyone tell me what the audio quality is like on th E60 espeically for music? Is it stereo?
2. And does the phone support normal earphones? Are any inclued in the box?
3. Does the package include a memory card?
4. And can the E60 be used as USB mass storage device (plug-and-play)?
1. It is stereo.
2. With an adapter. Not included.
3. Don't know.
4. Yes (if it has a memory card).
N/A wrote:1. It is stereo.
3. Don't know.
3. No it didnt include in my pack.
The sale package is as:
1.- Phone
2.- Charger
3.- Battery
4.- Headphones (not good, you have to buy a good one)
5.- CD with respective software
6.- Memory card 64 MG
7.- USB cable
8.- User�s guide
It must come with the memory card, anyway you will have to buy a larger memory, I will buy a 2GB Mini SD memory for mine.
Regards
Does it support stereo head set with that adapter which comes with N80 and all?
I read its just mono speaker only.
mniko wrote:Does it support stereo head set with that adapter which comes with N80 and all?
The E60 only has support for mono (1.2) Bluetooth headsets directly.
The pop-port with a separately sold NOKIA earphone adapter plays stereo music. The sound quality is fair regarding the fact it's a business phone. Doesn't live up to the quality you get from music phones. I use "KOSS The Plug" earphones and get pretty vivid music out of my E60. Needs some EQ though...
Cheers
