My Nokia 7610 is restarting, please help me??
8 replies · 7,558 views · Started 06 May 2006
I have a Nokia 7610, then i start it it shows the Nokia Logo, and when the PIN screen comes, it restarts.
I have tryed to take the SIM card and the MMC card out of the phone, but the same happens.
Can anyone help me with this problem?
Kind regards.
Jonathan
Hello Jona in off position format your set by holding '3'+'*'+'Send' button and switch on by holding these 3 buttons I think by this your problem may solve...
for further information may email at my ID
Wirelessly posted (Nokia7610/2.0 (4.0437.4) SymbianOS/7.0s Series60/2.1 Profile/MIDP-2.0 Configuration/CLDC-1.0)
Call me and i tell u by*
somebody know how can i format my N 6600?
somebody know how can i format my n 3230?
somebody know how can i format my n 6230?
Hi!
i seem to have a very weird problem out here and i'm hoping someone will be able to help me. since last september my phones been acting kinda funny on and off. all of a sudden it just restarts and i have no idea y?
i've given it 2ice to a svc center but to no avail. later on i kinda found out that it was one of the themes i'd downloaded that was kinda conflicting with sumthing in my phone.well now after 4 months its started the same thign again!
and its the same problem....the theme! does sumone have a solution to my problem? or will i jst have to use my old themes....since the new ones seem to be conflicting with sumthing causing my phone to restart.
for ur info...memory is not a problem.i barely have anythign stored in my phone.i use the memory card to store stuff ...which is practically empty.
any suggestions anyone??
can u tell me how can i format my nokia 7610??
i just want to know can i format the phone just use that phone and i dont want to using usb cable..
and..if the data in my phone will be delete..
can i restore or found it??
hey there, i have a nokia 7610, one day i switchd off my phone to save battry as i was not gonna need it, after i returnd and tried switchn it on, the "NOKIA" welcome screen came on, slowly faded and the the welcome screen turned on again. This process was repeated 3 or 4 times and finally the screen faded and the phone switched off. I tried charging the phone but it did not charge. i tried with a different nokia charger as also a battery of my friends who has the same phone,, yet the welcome screen and fade process kept repeating.
I dont know whats wrong? anyone have any ideas or solutions to solving this problem??
thanx
i dont know if this will work on your phone...
try it on standby mode... type *#7370# or *#7780# and a prompt question will appear... "Restore all original device settings? Device will restart" YES/NO option. if you choose YES,,theres a lock code: type 12345. hope this will helps you a lot.
thats the only advice that i can give.
