Lifeblog
2 replies · 2,509 views · Started 06 May 2006
I've been using an N90 but thought I might prefer a candybar so ordered an N70 (which I'm now returning - another story to do with a nick on the N90 screen I didn't notice so can't sell as planned) but when I used Lifeblog with the N90 it worked fine but when I tried to then use it (without any PC uninstalling) with the N70 it just hangs and invites me to cancel and restart Lifeblog. I've subsequently uninstalled from both PC and phone, removing manually all evidence of Lifeblog on both (and much is left behind on both!) tried again - same thing. Now hooked up the N90 again and the same thing is happening. Further uninstalled both on PC and phone and 'started again' but no change.
Any ideas?
Tim
Tim,
Which version of Lifeblog software do you install on your N70/N90? If it is Lifeblog 2.0 you are most likely facing one of the problems described here. A solution to that would be to download 2.0.24 for N70/N90 from www.nokia.com/lifeblog - it has been just recently updated.
Let me know if you'll continue to experience problems after installation of 2.0.24.
// Ivan
timsalmon wrote:I've been using an N90 but thought I might prefer a candybar so ordered an N70 (which I'm now returning - another story to do with a nick on the N90 screen I didn't notice so can't sell as planned) but when I used Lifeblog with the N90 it worked fine but when I tried to then use it (without any PC uninstalling) with the N70 it just hangs and invites me to cancel and restart Lifeblog. I've subsequently uninstalled from both PC and phone, removing manually all evidence of Lifeblog on both (and much is left behind on both!) tried again - same thing. Now hooked up the N90 again and the same thing is happening. Further uninstalled both on PC and phone and 'started again' but no change.
Any ideas?
Tim
Thanks for this Ivan. The thread makes interesting reading and I think describes the problems I was having with Lifeblog and the Nokia N90. I was using V2.0. I have now had the N90 stolen (well actually ripped off by someone on ebay on a sale - lost my £300) and went back to using the N70 (reversed my selling decision for other reasons). Lifeblog works perfectly with the N70, incidentally. Not sure why it started behaving but suddenly did when the N90 was out of the picture.
Tim
