chairthatsqueak wrote:hi,
reposting this query from another thread.
I've just had my orange n70 flashed with 5.0609.2.0.1 01-03-06 RM-84 firmware and I now can't download the orange tv app (it returns an 'unable to verify certificate' error on download) according to orange i can't unsubscribe from the service without using the application so i'm a bit stuck. does anyone have any thoughts as to how i can proceed, when my trial period runs out i'll be paying �10 a month for a service that I apparently can't access or remove from my account.
i know i should have looked into this before i flashed the phone but given that i've ballsed that up, does anyone have any thoughts as to how i might proceed?
cheers
To be honest, if Orange find out that you have flashed the handset with generic firmware, they may become even more unhelpful. :frown: Your best bet is to phone up OCS and say that your handset has "lost its settings" and could they re send the security certificates back to your handset. If they refuse then you may (I stress 'may' because I've never done it myself) be able to copy the security certificate from a friend that has an N70 also on Orange.
If I go to Menu > Tools > Settings > Security > Certif. management
I can see that I have a certificate marked "Orange Java Mobile" in the Authority tab, I have no personal certs that I can see.
Details are as follows:
Label:
Orange Java Mobile Device Root
Issuer:
Orange Java Mobile Device Root, Orangeworld SA, GB
Subject:
Valid from:
30/09/2003
Valid until:
30/09/2013
Cerificate Location:
Phone memory
Certificate format:
X.509
Algorithm:
SHA1RSA
Serial number:
probably handset specific, based on IMEI? Hence I'm not printing it sorry.
Fingerprint (SHA1):
Fingerprint (MDA5):
I'm guessing you need that security certificate to be able access all areas of the Orange World Portal.
Bear in mind that you will have also lost Orange specific applications (in addition to the much hated HomeScreen) such as pvPlayer and Orange's version of Push To Talk - Talk Now.
Good luck in your dealings with Orange Customer Services. You may want to dial 156 as opposed to 150 as the people there are more geared towards technical queries.
S.
