Sync Software for Outlook 2003
1 replies · 5,706 views · Started 08 May 2006
I just bought E61. The sync software that came with it from Nokia is lousy. What are the best sofware solutions (3rd party) for syncrnonization...
PLEASE HELP!
Define lousy and not lousy 😊 It is easier to suggest something if you describe that is bad in Nokia solution (I take you refer to Nokia PC Suite or..?) and what you need instead
