Has anyone got this app working on the N70? It seems to load up and lets you 'set' it up, forces a reboot then nothing happens. Or am I doing something wrong? Maybe this is one of the apps that won't work on this version of S60 like Vexed etc...
Tim
Tim
timsalmon wrote:Has anyone got this app working on the N70? It seems to load up and lets you 'set' it up, forces a reboot then nothing happens. Or am I doing something wrong? Maybe this is one of the apps that won't work on this version of S60 like Vexed etc...Works perfectly for me. After you have installed the application and run the setup file, you then need to select it as a ScreenSaver. Goto:Tim
Menu > Tools > Themes > Select your current active theme > Edit > Screensaver
You then need to change this setting to the new option that has appeared called 'gosymbian'.
Should work, does for me! :icon14: 😎
S.
Many thanks. Sorry - I now see that all that's explained in a link from the apps homepage. I must look more carefully next time - what a buffoon!
Tim
