Hi All
Cna someone help me to configure the WLAN connection, and also when i click on the web button the Connecting via GPRS starts to connect, but i want to use the WLAN connection.
Hi All
Go to MENU,
SERVICES,
OPTIONS,
SETTINGS,
Select Always Ask Under ACCESS POINT and it will ask you choose from a list of available access points.
You can also specify a default access point and I suspect that your current default is your GPRS connection.
Hi there
Thanks for the help, now how can i set a default page to work with the new web browser. Your help is much appreciated
Hi there
