WW2 Skins
3 replies · 1,729 views · Started 22 January 2002
Loony, I downloaded your skin about WW2, but the background of Desk is too short!
Could you send the adjusted jpg files to me, please?
Regards!
Update and new skins comeing up tomorrow User posted image
But strange non the less..On mine it�s a perfect fit...Hmm
But anyways..I�ll still update it User posted image
Thanx for pointing it out to me
But I don�t understand, because other skins worked fine in my comm before and after upgrading. ??.
BTW, I don�t know if you have the same problem, but the backgrounds (462x200) are too short in my comm, I have to use 463. And I use 114 for the right panel, I think it�s a correct size for the most of the possible views (then the image doesn�t repeat itself).
Well, I�m wishing for your update! User posted image
And BTW, Flipside, I�m very sad because I don�t understand completely your new idea about making skins (damn, due to my bad English! User posted image ). I�ll go on with the out of fashion mode, hehehe User posted image
Regards!
