Hi, Can someone please help, I`ve been trying to put Route66 mobile 7 onto my N-gage without any joy, I keep getting system error message.
I put the folder route66 under the apps folder, which creates an icon on the main menu which looks like a jigsaw piece with route 66 written underneath it. But evertime I select the icon I get the error message system error.
Has anyone come across this?
Am I doing something wrong??
Pete😊
does route 66 mobile 7 support the QD?
Only Route 66 2005, works in N-Gage. Mobile 7 demans more memory!
Only Route 66 2005, works in N-Gage. Mobile 7 demands more memory!
Wirelessly posted (NokiaN-GageQD/1.0 SymbianOS/6.1 Series60/1.2 Profile/MIDP-1.0 Configuration/CLDC-1.0)
More memory, not more ram? Qd has lots of ram and the memory has never been an issue before. Where can route 66 2005 be purchased from then?
Yes, more RAM. Not more MMC... I saw once a try in a QD with Mobile 2005, and everything works, than with Mobile 7 don�t run. Purchase now, I don�t know. Maybe in Route 66 site, with special demand... Maybe...
more than 16mb ram?
I dont believe you.
where's the official route 66 site?
www.66.com
System requirements
Your smartphone must have the following specifications:
- Symbian OS v6.1 or higher
- Series 60 platform 2.0 or higher
N-gage is Series 60 platform 1.0, thats why it wont work, route 66 no longer supports the Ngage platform.
Also means it no longer supports the SX1 or the Sendo X
I`ve just bought route 66 mobile britain 2005 from ebay for �25, It works like a dream on the N gage.
Keep on eye on ebay or I could send you the e-mail address of the ebay shop I purchased it from, they may have another 1
Thanks for everyones replys
Pete
