Is there a place I get a free full version of the fs caller? The only ones I find are the demo versions.
N70 fs caller
Assuming you're not talking about illegal activity in AAS, you can buy it here... http://my-symbian.com/s60/software/applications.php?fldAuto=589&faq=2
Tim
No illegal activity intended on my posting. I just want to make sure thre are no free ones out there before actually buying the software. I was just using a common logic when shopping around.. Why would you buy something that you can get for free somewhere legally? But since I guess there aren't any free ones, then buying it is the only option to get the full version. Thanks
No offence intended. Enjoy the program.
Tim
There's a free one (tho' not as many features) - Powercall.
Sian wrote:There's a free one (tho' not as many features) - Powercall.
Do you have a weblink for Powercall's Full Screen Caller? I've done a Google Search, and looked here at My-Symbian but have been unsuccessful at finding the software.
TIA
Cole 😉
timsalmon wrote:powercall symbian on Google threw up this in 4th place... 😉Tim
Wonderful!! Thank you, Tim.
Now after installing PowerCall and testing it, I was under the impression it would grab the photo out of my Contacts database and display it full screen, but instead it is showing a default photo that comes with PowerCall. The contact's photo is also in my Gallery>Images folder. This is the same thing Full Screen Caller software from SmartAppz is doing. The mobile phone I am using is Nokia N70.
Am I misunderstanding the purpose of PowerCall or Full Screen Caller?
No idea - never used it - perhaps you should ask Sian, who suggested it, above.
Tim
You need to go into Powercall to assign the caller id again. A bit troublesome.. but take that as the 'cost' for saving you some buck$. : )
By the way, with Powercall activated, you can't access 'Loudspeaker' without first come out of it (by pressing the left softkey i think). That's one shortcoming to me. You can't activate 'Loudspeaker' before the call is connected. Need to wait for the call to be connected first.
Sian wrote:You need to go into Powercall to assign the caller id again. A bit troublesome.. but take that as the 'cost' for saving you some buck$. : )By the way, with Powercall activated, you can't access 'Loudspeaker' without first come out of it (by pressing the left softkey i think). That's one shortcoming to me. You can't activate 'Loudspeaker' before the call is connected. Need to wait for the call to be connected first.
Thank you, Sian. It now works like a charm. :icon14:
Coley
