Hi all
IS there Anything like printf in c or Msgbox in VBasic in Symbian ? Whixh is it ? And how do I use it to show some data inthe screen of the 7650??
Hi all
The simplest API to use is CEikonEnv::InfoWinL(), which displays two lines of text in a message box.
to show some TDesc-Stuff on your 7650-Emu screen just use: iEikonEnv->InfoMsg(string); or just iEikonEnv->InfoMsg(_L("Test123"😉;
C'Ya
11/25/02 07:09AM
Hi
Thanx
I have the following code
RNotifier not;
User::LeaveIfError(not.Connect());
TBTDeviceSelectionParams param;
TUUID btid(0x001f82e2);
param.SetUUID(btid);
TBTDeviceSelectionParamsPckg pckg(param);
TBTDeviceResponseParams result;
TBTDeviceResponseParamsPckg response(result) ;
TRequestStatus status;
not.StartNotifierAndGetResponse(status,KDeviceSelectionNotifierUid, pckg, response);
User::WaitForRequest(status);
TPtrC name;
if (status.Int() == KErrNone)
if (result.IsValidDeviceName()) {
name.Set(result.DeviceName());
not.CancelNotifier(KDeviceSelectionNotifierUid);
not.Close();
Now, my question is how do I show the found Bluetooth device name(which should be in the TBTDeviceResponseParams result, and kept in TPtrC name) in the screen of the 7650?
Thanx a lot
First comment: you shouldn't really be using User::WaitForRequest() like that in an application, as it will lock up your GUI while the notifier executes.
But anyway, to display the name, just type "CEikonEnv::Static()->InfoWinL(name, KNullDesC);"
Hi
Thanx a lot......it comliles, I will test it in the phone after a moment........one question, how should I use the User:WaitForRequest?
The right thing to do is not to use User::WaitForRequest at all 😊 The code should be encapsulated in an active object. Active objects are a fairly large topic, so I won't go into detail here, but see http://www.symbian.com/developer/techlib/papers/tp_active_objects/active.htm for more information, or the SDK, or the source code of CBluetoothHandler in the open source "Bemused" application.
