N80 Operator logo
4 replies · 4,201 views · Started 11 May 2006
Hi
I've managed to send an operator logo to my phone ota but as I was just testing, I've ended up with a crappy monochrome logo. I know I can select whether to show the logo or not but cannot find the location of it using SExplorer. Does anyone know where this should be? I'm guessing it gets stored in one of the protected folders which can't be opened by SExplorer.
Also, would I be right in thinking that the op logo on the N80 should be bigger than 97x25 since the screen is a higher resolution?
There's naff all on the web on op logo's for the N80.
Any help much appreciated. 😊
You are right, the logo's live in a restricted area on S60 V3 phones. Nokia are playing tight arse with their certificates so beyond OTA, I think we are out of luck for the time being unfortunately.
FExplorer won't help; it is not going to get the required privileges/capabilities on S60 v3.
