Tom Tom CurrentMap.dat on N70
5 replies · 4,525 views · Started 12 May 2006
I have transferred TomTom 5 Moible onto a new memory card for my new Nokia N70, but TTM5 fails to find the MAP files.
The Map files are in a folder (caleed Great-Britain-Map) on the root of my memory card (which is called Memory card).
What I want to know is, what text string i need to put in the CurrentMap.dat file that is located in the \system\Apps\TTMOBILE folder ??
Can anyone with a Nokia N70 and TTM5 please help.
Cheers
Ade
ademason99 wrote:I have transferred TomTom 5 Moible onto a new memory card for my new Nokia N70, but TTM5 fails to find the MAP files.
Cheers
Ade
Just E:\Great_Britain-Map\
But can't you just copy over the entire contents of your original TomTom card? In my experience, these installations are quite complex and it's best to start with the real files.
Steve
Hi
I have a 6630 which I have TT mobile 5.2 on, my wife has a N70 and I've also added it to her memory card. The way I did it with both was to use a card reader, I took my card from the 6630 copied that via the card reader to my pc then I placed my wife's card in the reader and copied the file back to her card.
When I clicked on the TT icon in her my folder it started up no problem, I did have to enter the authorisation code again. I hope this helps.
Andy
daniel_gomes wrote:
We can unlock Nokia N70 by imei for 49 pound
send your imei and network of nokia n70
to: [email][email protected][/email]
Wow what a bargain... NOT 🙄 and my network only wants £20 to unlock my phone.
S.
