can anyone tell me tha software that you can create themes that are compatible with nokia n80?
thx
thx
Bump, id like to know that also
Nokia's 'S60 Theme Studio 3' has been out for a few weeks, but it's not exactly user friendly. It's a 75mb download.
From their release notes:
"S60 Theme Studio 3.0 for Symbian OS is a PC tool to create theme packages
for S60-based devices (for devices based on S60 Developer Platform 3rd
Edition). The tool allows the user to mix or change the properties of
ready-made theme components and bitmap images. However, the tool is not
meant to create or extensively edit bitmaps. Commercial pixel editing,
vector editing, sound editing program should be used together with the
tool for significant image/sound editing. The created theme packages can
be saved to hard drive and then deployed to a device using some other
method supported by both the phone and the PC (e.g. bluetooth)."
