I was wondering where I can find the scandisk and defrag functions on Nokia N91???
l've been able to find the format function(s) ,but not the others....
l've been in : tools--->harddisk-->options--->tools ... but l only see the fomat functions!!!
...or for that mater is there such a function?? It is mentioned in the help file on the phone it self but not in the user-manual?? :con?
Thanks in advance!
DeBo
hey i have the same problem as well. those functions are no where to be found !
can it be that the firmware that i'm using is of a different one??
im on V1.00.028.13 29-03-06 RM43
that is a good question..... but... I don't actually know how to check the firmware version? 😞
connect it as a mass storage and do it from ur PC
but isn't there any way to do it directly from the phone??:con?
there might be a difference between the Euro Prototype and the official Nokia released ones.. which firmware are you on right now?
my firmware :
V1.00.028.03 29-03-06 RM43
hi all
pls connect ur phone to pc via dke-2 and select it as mass storage, den u will see it drive on ur pc, jst rite click and u can scan or defrag it
good luck
yeah i've tried this and it works. im just baffled that nokia decided to remove the scan and defrag tools from the hard disk options.
I know there are other n91 phones that have these options that allow you to do it on the fly i.e. not needing you to detect the n91 hard disk as a mass storage. there must be a reason why nokia decided to remove them in the first place.
My thoughts exactly.... It's is rather odd that Nokia decided to leave a group with the function(s)...while deactivating it others...... interesting...
I know about the mass storage "trick" ...but I was hoping to find a way to do it directly from the phone it self...ahh well can't get everything... 😞
Cheers
DeBo
there was a disk defrag option in pre-release version of N91,but I do not know the reasons why Symbian took it off. It was next to the format hard drive option.
hopefully newer releases of the firmware of N91, in the future will include it, or some will create an application.
