hello all,
I have just received my third N70 from Vodafone!
I have a problem with recharging the battery.
Say the battery level bar is at 1 bar (out of five). I put the charger in, the "charging" message comes up and the bars start increase to indicate it is charging, however after a good period of charging (i.e 2 hours) i take the charger out and the battery level is at the same level as when i put the charger in! (i.e 1 bar)
It is not a falut with the battery as i have a spare and swapped them over and it happened to the other battery as well.
Finally if the battery is completely empty and the phone is off, when i put the charger in nopthing happens what so ever - it doesn't even register that there is a charger.
I am at a loss - shall i ask for my fourth N70!?
Wirelessly posted (NokiaN-GageQD/1.0 SymbianOS/6.1 Series60/1.2 Profile/MIDP-1.0 Configuration/CLDC-1.0)
Which charger are you using? The new version or the adaptor for the old version.
tbone78 wrote:hello all,I have just received my third N70 from Vodafone!
had that prob on my old 6680,got the firmware upgraded and that sorted it,you should try it with n70
I using both the new charger and my old cahrger with the N70 adaptor.
do you know what the most current firmware i should load is?
Hi all,
I just have the same problem with charging, after 15min of trouble shooting, i figure out that the charger is bad. I buy an after market charger, with output 5VDC, 1000mA, cut out the connector and replace with the one Nokia one, make sure the polarity is + (positive) inside, -(negative) outside. Plug in and charge your phone, it work like a charm now. I know the charger come with the phone is suck, so better replace your. Hope this will help.😊
I also have a battery problem. I got my N70 one month back. Very 1st day i charged it nearly 6 hours. After that normal charging till the phone says enough. But my battery is not long last more than a day. Even i use or not radio, camera and mp3 listening, result is same
Can u guys tell me how to rectify this problem..?:frown:
try to drain out your battery by let it run all the way down, dont charge your fone till it dead, then give it a complete charge for 8 hours, this will help.
