Strange GPRS
2 replies · 1,597 views · Started 25 November 2002
I "Sometimes" I find intiating a GPRS connection troublesome. It does'nt connect for some strange reason and gives the error (Connection Failed, check ur GPRS account on your Phone)
It connects just fine after a couple of times (but only after u select another access point and then back to original).
This happens even when no settings have been disturbed. Anyone else experienced this? 😞
I can imagine only 2 possible causes (might sound stupid 😃 ):
1) You have some stuff in your outbox (email or MMS) and your 7650 tries (and retries) to send it, or
2) Your phone has to receive an MMS but fails (maybe wrong MMS settings in your phone, or operator account?)
If you don't have anything in outbox, and you can send & receive MMS normally, then I would like to know (if u ever find out) what the hell causes this!!! 😃
I have the same thing sometimes (ver 3.16)
I just change the settting from gprs automaticly by signal to gprs when needed..or the other way around..then it works again.
