3250 with TomTom 5
5 replies · 6,562 views · Started 17 May 2006
Just got a 3250 and was under the impression this was compatible with TomTom Mobile, however when i try to install the file, i get an error message:
TomTom Mobile 5.sis not supported?
Could anyone please advise on what i should doo to get this working?
Tomtom Mobile 5 is not for OS9.1 / S60 v3.
Only OS 7 (6600, 3230,...) or OS 8 (6680, N70...).
Are brilliant:frown: I got the 6280 last week after being advised it was a compatible phone, found out it wasn't is it was symbian 40 and needed to be symbian 60, so on more advice got the 3250 believing this to be compatible and this one symbian 60 isn't either😮
Can you tell me will it be compatible in the future or is there another navigation software that will work as good as tomtom?
thanks in advance!
Sorry if question has been asked already but what is the version (if exists) of a tomtom software working on 3250 ?
Thank you.
