what certification category I need for ICMP sockets?
11 replies · 0 views · Started 17 May 2006
Hi, I am trying to port my ping application to S60 3rd edition but when I
try to open a datagram socket with the protocol ICMP or IP (this is the way
in which I implement ping in S60 2nd edition) I obtain the error -47
(KErrPermisionNotSupported). The phone I'm using is Nokia N80.
I'm using a certificate obtained from symbiansigned. I wonder which is the
certification category I need in order to implement a ping in S60 3rd
edition. is it needed to obtain a ACS publisher ID? or is it needed to be
approved by Phone Manufacturer?
Thanks in advance
Almudena
> Thanks in advance
> Almudena
At best I think you need NetworkServices; at worst you may need
NetworkControl. The latter is a phone manufacturer approved capability I
think.
So you've got a DevCert without an ACS id? Are you sure you can get
NetworkServices capability on such a DevCert. If not then that is where
your problem may lie.
AMK
I have searched in Symbian documentaci�n and with the developer certificate
obtained from Symbiansigned without a ACS published ID it is possible to
access to network services capacity. So I think it is need to obtain phone
manufacturer approbation.
Almudena
"AMK" <[email protected]> escribi� en el mensaje
news:n$ZsIXleGHA.380@extapps30...
> sympa wrote:[color=green]
>> way
>> the
>> Thanks in advance
>> Almudena
> think.
> AMK[/color]
"sympa" <[email protected]> wrote in message
news:2TBBeCeeGHA.1044@extapps30...
> way
You mean KErrPermissionDenied (-46) ... This kind of app can be tested on
emulator and there should be an event in %TEMP%epocwind.out telling you
exactly what capability is missing ...
> Thanks in advance
> Almudena
Hi, I have tested the application on emulator and I have obtained error
"-28" (KErrBadName). After that I have checked epocwind.out but capability
warnings don't appear.
Any idea?
"Escu" <[email protected]> escribi� en el mensaje
news:5Yb1fEqeGHA.2620@extapps30...
> news:2TBBeCeeGHA.1044@extapps30...[color=green]
>> way
>> the
>> Thanks in advance
>> Almudena
>[/color]
That is a bad syntax error, not a platsec warning, so you won't necessarily
see anything in epocwind.out.
Your socket declaration is probably incorrect. Perhaps you're opening a
socket to a non-existant protocol. Not easy to tell without confirming
a)thats the call raising the error, b) what exactly you are calling.
Regards
Hamish
news:6tDfzUzeGHA.1044@extapps30...
capability
> Any idea?
> news:5Yb1fEqeGHA.2620@extapps30...[color=green]
> > news:2TBBeCeeGHA.1044@extapps30...[color=darkred]
[/color][/color]
I[color=green][color=darkred]
> >> way
> > You mean KErrPermissionDenied (-46) ... This kind of app can be tested[/color][/color]
on[color=green]
> >[color=darkred]
> >> the
[/color][/color]
be[color=green][color=darkred]
> >> Thanks in advance
> >> Almudena
> >[/color]
>[/color]
Ok, thanks.
When I try to open a socket in this way:
err=iRawSocket.Open(socketServ, KAfInet, KSockDatagram,
KProtocolInetIcmp);
I obtain error -28 on emulator an error -47 on mobile phone N80 (Symbian
9.1). But when a I try this code on Nokia 6680 (Symbian 8.0a) I have not
obtain error, it works successfully.
Regards
#endif
"Hamish Willee" <[email protected]> escribi� en el mensaje
news:wbZACBWfGHA.1912@extapps30...
> necessarily
> Regards
> Hamish
> news:6tDfzUzeGHA.1044@extapps30...[color=green]
> capability
>> Any idea?
>> news:5Yb1fEqeGHA.2620@extapps30...[color=darkred]
>> >> when
[/color]
> I[color=darkred]
>> >> the
>> >> way
[/color]
> on[color=darkred]
>> >> the
[/color]
> be[color=darkred]
>> >> Thanks in advance
>> >> Almudena
>>[/color]
>[/color]
I have tried to do the same on S60 3rd Ed.
I am not sure about the solution, because my app does not work yet, but here
are my current assumptions:
I think the 3rd Ed SDK Help says "Illegal Capability" for the API you are
using.
TInt Open(RSocketServ &aServer, TUint addrFamily, TUint sockType, TUint
protocol);
I don't know what "Illegal Capability" means, but my code did not work on
3rd Ed either, although it worked on 2nd Ed and I had NetworkServices etc.
capabilities that are available with ACS publisher ID but without
manufacturer's explicit permission.
When I noted the "Illegal Capability" thing in the Help, I decided to use
the API
protocol, RConnection &aConnection);
but this seems to require NetworkControl capability for KProtocolInetIcmp
sockets.
(Trying to run the app without NetworkControl capability in the device gives
a security error.)
For NetworkControl capability you need device manufacturer's permission, I
think. I filled the manufacturer's permission request form a week ago but
have received no response yet.
Best regards,
Jyrki
www.aspicore.com
news:F1TMiyafGHA.1040@extapps30...
> Ok, thanks.
> KProtocolInetIcmp);
(Symbian
> Regards
> #endif
> news:wbZACBWfGHA.1912@extapps30...[color=green]
> > necessarily
> > Regards
> > Hamish
> > news:6tDfzUzeGHA.1044@extapps30...[color=darkred]
> > capability
> >> Any idea?
> >> >> when
> > I
> >> >> the
> >> >> way
[/color][/color]
tested[color=green]
> > on[color=darkred]
[/color][/color]
you[color=green][color=darkred]
[/color][/color]
is[color=green][color=darkred]
> >> >> the
[/color][/color]
3rd[color=green][color=darkred]
[/color][/color]
to[color=green]
> > be[color=darkred]
> >> >> Thanks in advance
> >> >> Almudena
> >[/color]
>[/color]
Hi, thanks for you response, I have found this in SDK help:
"For instance, a process needs the NetworkServices capability to open a TCP
or UDP socket. Hence a process also needs the NetworkServices capability to
transfer a TCP or UDP socket. Similarly, a process needs the NetworkControl
capability to open an IP or ICMP socket. Hence a process also needs the
NetworkControl capability to transfer a IP or ICMP socket. "
Where I can find manufacture's permission request form?
Regards,
Almudena
"Jyrki Ettil�" <[email protected]> escribi� en el mensaje
news:GoVbc7kfGHA.972@extapps30...
> here
> using.
> protocol);
> the API
> sockets.
> gives
> a security error.)
> Best regards,
> Jyrki
> www.aspicore.com
> news:F1TMiyafGHA.1040@extapps30...[color=green]
>> Ok, thanks.
>> KProtocolInetIcmp);
> (Symbian
>> Regards
>> #endif
>> news:wbZACBWfGHA.1912@extapps30...[color=darkred]
>> > necessarily
>> > Regards
>> > Hamish
>> >> error
>> > capability
>> >> Any idea?
>> >> >> when
>> > I
>> >> >> the
>> >> >> way
>> >> >> error -47
[/color]
> tested[color=darkred]
>> > on
[/color]
> you[color=darkred]
[/color]
> is[color=darkred]
>> >> >> the
[/color]
> 3rd[color=darkred]
[/color]
> to[color=darkred]
>> > be
>> >> >> Thanks in advance
>> >> >> Almudena
>>[/color]
>[/color]
On the Symbian Signed website, when you create a request for the dev
cert; at the bottom there's a link for manf approved dev cert.
AMK
> Regards,
> Almudena
> news:GoVbc7kfGHA.972@extapps30...[color=green]
>> here
>> using.
>> protocol);
>> the API
>> sockets.
>> gives
>> a security error.)
>> Best regards,
>> Jyrki
>> www.aspicore.com
>> news:F1TMiyafGHA.1040@extapps30...[color=darkred]
>>> Ok, thanks.
>>> KProtocolInetIcmp);
>> (Symbian
>>> Regards
>>> #endif
>>>> necessarily
>>>> Regards
>>>> Hamish
>>>>> error
>>>> capability
>>>>> Any idea?
>>>>>>> when
>>>> I
>>>>>>> the
>>>>>>> way
>>>>>>> error -47
>> tested
>>>> on
>> you
>> is
>>>>>>> the
>> 3rd
>> to
>>>> be
>>>>>>> Thanks in advance
>>>>>>> Almudena
>>[/color]
>[/color]
> AMK
>> a TCP or UDP socket. Hence a process also needs the NetworkServices
>> capability to transfer a TCP or UDP socket. Similarly, a process needs
>> the NetworkControl capability to open an IP or ICMP socket. Hence a
>> process also needs the NetworkControl capability to transfer a IP or
>> ICMP socket. "
[/color]
Could someone please tell me that I do not need manufacturer approval to use ICMP on my
telephone?!
What kind of damage could I do with an ICMP ECHO REQUEST?
Dirk
Hi Dirk
I encountered the same problem with the ICMP-requests. I'm afraid but the
capability NetworkControl is definitely necessary to open an ICMP-socket.
Br
Jan
"Dirk Jaeckel" <[email protected]> wrote in message
news:[email protected]...
> AMK wrote:[color=green]
>> AMK
>> sympa wrote:[color=darkred]
>>> ICMP socket. "
[/color]
> use ICMP on my
> telephone?!
> Dirk
>[/color]
