i may be being really thick this time, but how the hell do you browse the tones and maybe send the odd one to friends?? the ones i've uploaded are accessible but can't find the ones on the phone at all.
quick question on tones
you need a file explorer and then navigate to your Z: folder and find them there
ok, thanks. guess i'll wait till a good one comes out, or can you recommend one thats compatible and available
SExplorer is the only one that fits the bill right now: http://simonjudge.com/symbianseries603rdfreeware.html
You will have problems forwarding ringtones because they are considered protected content. I believe this is the OMA Forward Lock DRM at work.
