Using the N80 and a Nokia 610
0 replies · 2,009 views · Started 18 May 2006
Hi all,
My first post so a big hello from me and if possible I wish to pick you brains. I have a Nokia 610 car kit which has worked using the sim access profile on both a 6230 & 6230i for a few years now and I love it. I have read that the N80 will work with the Nokia updated car kit the 616 now its using the newer S60v3 operating system. Now do you guys think im correct that as it allows the sim access profile on the 616 it should work on my 610? Or am I way off? Also what are the chances of me using this setup using bluetooth connection to the 610 and using a bluetooth connection at the same time to a gps unit once TOMTOM finally comes out? I know I might be expecting a bit much here but I think some bluetooth headsets work as well as bluetooth gps systems.
Anyone help me figure out if this will work? Im guessing I might have to take the plunge and find out.
Cheers
Adam
