Motorola A1000 agps problem
1 replies · 3,964 views · Started 18 May 2006
Hi.
I've just got my A1000 and I'm trying to get the wayfinder gps software to work.
The program starts just fine but doesn't seem to get a gps signal from the internal GPS.
I tried a friends BT GPS reciever and that worked great.
Do any of U guys know what to do?
Cheers
I dont know your location but the A1000 with Wayfinder6 works great in Stockholm, Sweden with the built in GPS reciever. Make sure to chose "built in GPS" in the menue!
Usually you get a fix in 30 seconds depending on how many satelites are in sight view. It varies from time to time during the day. and location on earth. Dont, hold your hands in top of the A1000. If you do so you will obstruct the GPS antenna.
I have also tried the GlobalSat BT338 20 channel Sirf III but it took about the same time to get a fix with the external BT GPS reciever.
